Compressor clutch problem
Gearshift on Fri February 22, 2008 2:19 PM User is offline
Year: 1994
Make: Honda
Model: Accord
Engine Size: 2.2
Refrigerant Type: 134A
The compressor clutch does not engage. I checked the fuses and clutch relay, they are OK. Any suggestions on the next step. ,Thank you for your advice. 1994 Honda Accord EX.
GM Tech on Fri February 22, 2008 3:17 PM User is offline
Put a gage set on it-- any pressure??? Most likely not enough to make the low pressure switch or transducer- the number one cause of automotive a/c failure is loss of charge due to a leak.......so I am playing the percentages here......
