ac leak in system
wirenet on Fri February 15, 2008 12:59 AM User is offline
Year: 1992
Make: honda
Model: accord
Engine Size: 2.2
Ambient Temp: 80f
Pressure Low: 34
Pressure High: 175
Gentlemen last October I was getting an ac leak in my ac system I injected dye and looked for the leak.Unfortunately a few years earlier i had injected dye to find another leak and had fixed that leak. The problem I am having trying to dist - inguish old dye leaks from new dye leaks. The question i am asking is there newer dye out that gives off a different color then the old dye and if there is where can I purchase it. Or is there some thing I can purchase to remove the old dye residual color and start afresh. Thank you.
Edited: Fri February 15, 2008 at 1:02 AM by wirenet
TRB on Fri February 15, 2008 12:49 PM User is offlineView users profile
Your standard spray on engine cleaner should remove most of the old dye.
Edited: Fri February 15, 2008 at 12:50 PM by TRB
iceman2555 on Fri February 15, 2008 5:04 PM User is offlineView users profile
Was cleaning out the 'ole' attic at the shop....found a case of R12 w/dye......now if only could figure a way to remove the dye....and use the 12.....think Ill save...after all the Smithstonian may wish to make an exhibit some day.....!!!!
TRB on Fri February 15, 2008 5:07 PM User is offlineView users profile
About you or the R12?
iceman2555 on Fri February 15, 2008 5:11 PM User is offlineView users profile
Both.....right next to the "Prehostoric' section!!!
And I thought we missed you a MACS........
How are you doing these days. I was scheduled for your area next week...but plans have changed...be there in March....have to get over!!!
TRB on Fri February 15, 2008 5:16 PM User is offlineView users profile
Sure it's not an addition to the Prehistoric section? Bring the corporate card!!!
iceman2555 on Fri February 15, 2008 5:20 PM User is offlineView users profile
Yeah gads..forgot to hit the 'spell check'....been sniffing that stuff toooo much.....got the card...know a good steak house.....invite Karl......maybe he will pay......
TRB on Fri February 15, 2008 5:23 PM User is offlineView users profile
Karl will be here the 24th I think.
iceman2555 on Fri February 15, 2008 5:27 PM User is offlineView users profile
You are sooo lucky...coming the 17th....headed to St Louis on the 24th. Hope it is not cold there........!
