2002 Sable orifice
phil55 on Fri January 18, 2008 11:39 AM User is offline
Year: 2002
Make: Mercury
Model: Sable
Engine Size: 3.0
I am going to replace orifice tubes.Leakinf front seal on comressor.Anyone know where the two orifice tubes are located on 2002 Sable,Taurus?
JACK ADAMS on Fri January 18, 2008 12:33 PM User is offline
On this application, it will be located in the liquid line (non-serviceable orifice). You will have to replace the liquid line to change the orifice tube. Here is a link for Black-Death. Be sure that you follow all steps to insure the new components that you are replacing.
Hope this helps and good luck!
Chick on Fri January 18, 2008 12:47 PM User is offlineView users profile
96 to 99 had a fitting where you could access the O tube, as shown in the pic below. It's on the passenger side running along the frame. You might be lucky and have such a fitting. Not really sure on the 02... If the fitting is there, you have to peel away some of the foam to get at it..If not, it's as Jack says, and the line must be replaced..
