A/C for motorcycle
syaokc on Fri January 04, 2008 2:01 AM User is offline
Hi,
Is it possible to drive an A/C system with a 250cc motorcycle engine? If yes, what's the impact on the fuel efficiency and power? Thanks
cochi
NickD on Fri January 04, 2008 5:38 AM User is offline
In a motorcycle?
syaokc on Fri January 04, 2008 11:42 PM User is offline
On a customized trike.
NickD on Sat January 05, 2008 9:13 AM User is offline
Seems like this question came up before, enclosed cab, I assume. 250 CC in my opinion is a bit light, even on a small bike, air cooled, and high winders with very low, low end torque. With the problem is how would you mount a compressor to it, only output that turns is that thing that moves the chain to make the rear wheel go, and my last bike didn't even have that, used a drive shaft instead. And these things never got good fuel economy considering the gross weight or what little of it, ha, had to stop every 90 miles or so to fill the tank, but had to stop anyway to wash the bugs off my goggles, couldn't see.
Would consider a small automotive engine instead like a Geo Metro or a Honda Civic, one that had air, would make the job a lot simpler. Some guy is putting a Corvette engine in a bike, doesn't even need a transmission, just a clutch.
graeme on Mon January 21, 2008 9:13 AM User is offline
Didnt a/c for motorcycles use to be an option along with ashtrays?
The Disturbed Crew on Thu January 24, 2008 3:43 PM User is offline
Try one of those Harley's with the small bore V8. I have only seen 2 of them and there is NO reason for a bike to have that much power. Of course they were with the Bandito's Motorcyle "club".
~Egotism is the anesthetic that dulls the pain of stupidity.
Frank Leahy~
TDC
iceman2555 on Thu January 24, 2008 6:20 PM User is offlineView users profile
For those that feel...the need for the largest.....
and for those that may be a bit more 'timid'...the BossHoss 502........
bohica2xo on Thu January 24, 2008 6:48 PM User is offline
Big, but without training wheels...
Nick may recognize the jugs on it. here is the rod set next to a harley set:
And for scale, here is a rider on it:
The scaled up springer front end:
Probably has enough reserve power for A/C - and riding it should make you sweat a bit!
B.
Edited: Thu January 24, 2008 at 6:49 PM by bohica2xo
