Year: 1995
Make: GMC
Model: K1500
Engine Size: 350
Refrigerant Type: R134
Hi all - Can anyone provide some guidance on how to get the magnetic clutch coil off an R4 compressor? I have the clutch plate and pulley off and both snap-rings are removed, but I can't tell what holds the clutch coil on. Thanks, Randy
It's pressed on, you need to "pry" it around the edges until it pops off..Hope this helps..
Edited: Sun October 28, 2007 at 5:12 PM by Chick
That helps; thanks. I wonder if you could use a three-legged puller and pull against the shaft?
I use a crow bar myself..Unless you need to save it, then you have to be careful not to bend it out of round...
Two big screwdrivers work for me-- Then tap in on with an old useless coil-- works every time..........
