readings!! how do they sound?
monky322 on Mon October 22, 2007 6:00 PM User is offline
Year: 1990
Make: toyota
Model: celica
Engine Size: 2.2
Refrigerant Type: r134a
Ambient Temp: 86
Pressure Low: 35
Pressure High: 189
Hey guys!! after suffering with my a/c installations. my car is done but i would like your opinions on this readings.
idle: low 35 high 189
1500 rpm: low 19 high 220
2500 rpm: low 15 high 210.
Vent temperature at 50 mph 49 degrees.
Car didn't have a/c, we got the parts from a junk yard. installed new compressor, expansion valve, condersor. system was r12. now r134a
Chick on Mon October 22, 2007 6:29 PM User is offlineView users profile
I would imagine that is on high blower speed? If so, the vent temps will drop on lower blower speeds while cruising the highway. Are you happy with it? They are small systems and don't take to retrofitting well, but when tweaked they are just fine..Pressures look good, make sure no air is going around the condenser, but being pulled thru it, make air dams if necessary.. the better the air flow thru the condenser, the better pressures and cooling will be...Good job...
And make sure no heat from the heater core is blending in with the evap air..Feel the suction line, should be cold right back to the compressor....
Edited: Mon October 22, 2007 at 6:36 PM by Chick
badufay on Mon October 22, 2007 11:06 PM User is offline
Like Chick said, double check the blend door, and try the vent blower at a lower speed. As I found out (from all these guys here), too much oil can also cause this along with an incorrect charge. Did you charge it yourself? If so, did you pull the vacuum and leave the gauges connected and then you charged it? Did you account for the amount of R-134a in the hoses and manifold (I know mine held about 3 oz or something like that)? What is the outside temp? Sounds like a big job you did, hope it works out for you. Also, don't waste your time with all that booster stuff, they don't work...I know. Still trying to track down some straight qwikboost however, Ackits actually tested this stuff and it showed some promising numbers (however it isn't going to drop your vent temps down to 30° F, read somewhere it is included in some Artic freeze stuff now, but it also has a bunch of sealers and crap in there too. There results are posted in the FAQ forum.
Ben
monky322 on Mon October 22, 2007 11:38 PM User is offline
yes, all the readings were at high speed fan. Well i read retroffiting cause the system to work less efficiently. Some people say 5 to 7 degrees more in comparison with r134a systems so i guess that is the best i can achieve(49 degrees) i am going to try to make the air go straight to the condenser and see what happens even couple degress less would do it for me. Thanks for your replies.
Well my wife is pretty happy with the little car so i guess, i am happy.
badufay on Tue October 23, 2007 12:44 PM User is offline
In case anybody cares, I wrote an email to the manufacture of Qwikboost asking what happened to it, and this is what they wrote back with:
Ben,
I am pleased you know Mainstream manufactures QwikBoost! We never stopped making QwikBoost. In fact, it’s so successful that it’s now being marketed by Interdynamics; who sells the product through just about every retail auto supply house in America.
Look for Interdynamic’s “Arctic Freeze” or similar products. They all use QwikBoost technology.
Thank you,
Ross Soyka
Marketing Supervisor
Mainstream Engineering Corporation
Ph: (321) 631-3550
Email: [email protected]
So bottom line is (in my opinion) they took a product that showed potential and threw it in with a bunch of other junk that now contains all that stop leak crap and made it...well Sh**. So like every other booster or enhancer stay away from this and if you still have doubts, search this forum for stop leak products and than make up your own mind!
Ben
TRB on Tue October 23, 2007 12:50 PM User is offlineView users profile
I have 9 cans of the original qwikboost.
badufay on Tue October 23, 2007 1:08 PM User is offline
Do you want to sell me one?
Ben
(not trying to get all sneaky with the private messages here, but i just don't know if your store sells that item or not, or if you just have some left over)
[email protected]
TRB on Tue October 23, 2007 1:24 PM User is offlineView users profile
Nothing sneaky about emails. Email me your shipping address and I'll figure a freight cost. Make a $ 10.00 dollar (per can) donation to the forum plus the freight cost. See link upper left (Support the Auto A/C Forum).
badufay on Tue October 23, 2007 3:43 PM User is offline
Called Rob and he took all my info...thanks again for your help!
Ben
TRB on Tue October 23, 2007 3:50 PM User is offlineView users profile
Glad we could help!
Wet in Washington on Tue October 23, 2007 8:16 PM User is offline
OK, so what is in quick boost that makes it so great?
Never take life seriously. Nobody gets out alive anyway.
iceman2555 on Wed October 24, 2007 11:34 AM User is offlineView users profile
Hey....TRB what type of flush did you use to get all the dust off those cans of QuikBoost....bet HECATS pulsating flush gun did wonders.....????
TRB on Wed October 24, 2007 11:40 AM User is offlineView users profile
I used our second set of rags. Could not use the first set as those are the good ones.
iceman2555 on Wed October 24, 2007 12:31 PM User is offlineView users profile
Ya'll finally getting it right...WW would be very proud......
TRB on Wed October 24, 2007 12:48 PM User is offlineView users profile
Careful now you're getting close to being banned!
