Vacuum vs Pressure Leaks
ewstan on Fri October 19, 2007 7:13 AM User is offline
Year: 1987
Make: Mercedes
Model: 300D
Engine Size: 3.0L
Refrigerant Type: 134
Gentlemen,
Is it possible for a system to hold vacuum but leak under pressure or vice-versa?
Wray
bohica2xo on Fri October 19, 2007 11:09 AM User is offline
Absolutely.
GM Tech on Fri October 19, 2007 11:40 AM User is offline
Double lip shaft seals will leak under vacuum if the teflon is damaged- yet the rubber lip will completely seal under pressure- seen it many times if the shaft seal protector tool is not used and the teflon is knicked.......vacuum leaks can take time to show on your gage- don't be in a hurry to charge after a deep vacuum..........
ewstan on Fri October 19, 2007 12:01 PM User is offline
Thanks for the replies. Reason I ask is that I just replaced the evaporator and the system has been sitting under deep vacuum for about 12 hours with no visible gauge movement. But there is a slight UV dye stain behind the clutch.
I can't rule out that the dye came from previous work on the system. Two shops worked on it without finding the evaporator leak and left a fair amount of dye around the A/C components.
I'm reluctant to install a new compressor without being sure the seal is leaking.
Would a reasonable course of action be to charge the system and see what happens?
Wray
mk378 on Fri October 19, 2007 2:33 PM User is offline
Dye there is a pretty good sign your compressor is leaking. You might charge just a couple oz of 134a so you have positive pressure and see if it is the kind of leak that will hold vacuum but open up under pressure. Either wait a couple days and see if the pressure goes down or check with a sniffer leak detector if you have one.
ewstan on Fri October 19, 2007 4:56 PM User is offline
Thanks. Will do.
Wray
