Found a Problem! What should I do!
gospel25514 on Thu September 27, 2007 1:11 AM User is offline
Year: 1997
Make: chevy
Model: Lumina
Engine Size: 3.1
I found a broken line around my battery/washer fluid container that appears to be a vacuum leading to a round container in my driverside fender wall. I have been having trouble with engine losing acceleration when the AC is on and air flow would come out the floor upon acceleration. Would this be the cause of my lack of power? Also how do you replace this line without taking fender off? It was snap completely into. Must have did it when I changed my battery. Any help would be great!
1997 Lumina
3.1L
Chick on Thu September 27, 2007 7:12 AM User is offlineView users profile
Go to any parts store and buy the little plastic hollow tubes used to join two pieces of vacuum line together and just splice them together at the break.. You can even find them in junkyard splicing winshield washer hose together where it goes up to the hood etc.. I think every car has one or two of them....
Cussboy on Thu September 27, 2007 8:13 AM User is offline
Sounds like a hard plastic vacuum line has broken; just replace the broken part with rubber vacuum tubing. It comes in several sizes, take in a broken piece of hard plastic tubing to match it up, and it's inexpensive. Yes, on some vehicles the heating, vent, and AC flaps or "doors" are controlled by engine vacuum, so could be the cause of air flow coming out the wrong place. On my old '84 Jeep Cherokee, I had to repalce two of the little vacuum actuators because pulling a vacuum on them did not move the actuator rod.
GM Tech on Thu September 27, 2007 8:35 AM User is offline
very common on W cars-- the battery gases eat away the plastic line- make it brittle and it snaps-- then you lose your air out the vents on acceleration........................splice it and and all will be fine..............
