Clutch Bearing
Bulldog Steve on Mon September 24, 2007 11:04 PM User is offlineView users profile
Year: 1995
Make: Mazda
Model: MPV
Engine Size: 3.?
Friend i work with has Mazda van MPV.
Says that the clutch is wobbling around on the Comp.
Can this bearing be changed and what is involved to do it (i.e.) spl tooling.
Thanks again for all you do here Guys.........
Steve
Chick on Tue September 25, 2007 5:32 AM User is offlineView users profile
The MPV uses the 10PA17C compressor, and this link should show you the exploded view including the bearing. However if your friend can see the pulley wobbling, the coil most likely got wiped out. Check that for 3 to 4 ohms before changing the bearing, as you may need a new clutch assembly.. If not, the pulley bearing is an easy swap on those..Hope this helps..
Chick on Tue September 25, 2007 5:41 AM User is offlineView users profile
This link shows the right page you want and the bearing number should be BG400... It's on the Denso 2 page...
