"Special Adapter" for Zexel comp.
Kai on Wed September 12, 2007 2:58 PM User is offline
Year: 1996
Make: Audi
Model: cabrio
Engine Size: 2.8L
Ambient Temp: 90
I need the “special adapter” to connect the low side hose of my 134a gauge set to the Zexel compressor Type DCW-17B on my Audi I was told it is a R12 connection but the R12 hose will not fit it is slightly to small.
Any idea where to get this?
Thank you,
Kai
TRB on Wed September 12, 2007 11:31 PM User is offlineView users profile
I see what I can find out from Valeo in the morning. Might email me reminder in case I get side tracked. Sure it is the low side you are having issues with?
Kai on Thu September 13, 2007 10:04 AM User is offline
Tim, I am pretty sure it is the Low side I will attach some text from the Audi service manual.
•On the following vehicles, no service connection is provided for the service station on the low-pressure side of the refrigerant circuit. Adapters are required for connecting the service station to the refrigerant circuit of these vehicles.
Service station, connecting with adapter V.A.G /10 to refrigerant circuit
•Unscrew cap from connection with valve - A - (at compressor).
•Attach O-ring - B - to connection (8.9 mm; 1.8 mm).
•Screw adapter V.A.G /10 - C - to connection - B - .
•Install valve opener - D - with appropriate seal in charging hose connection.
•Note:
•The type of valve opener - D - and seals required depends on the charging hose used (specific to manufacturer).
•The quick-release coupling adapter is not required for connection on the low-pressure side of Audi vehicles.
•Screw charging hose - E - (to service station) to adapter V.A.G /10.
TRB on Thu September 13, 2007 11:34 AM User is offlineView users profile
Not sure why I missed this last night. That is an R134a system. If you want to hook up your R12 gauges/hose you will need these couplers.
Conversion Couplers
Kai on Thu September 13, 2007 1:19 PM User is offline
Tim, sorry for the confusion
I own 134a gauges/hoses and R12 gauges/hoses
The problem is I can’t get any of them connected to the low side connection which is on the compressor.
It is a special threaded valve on the head of the compressor apparently 8.9mm diameter 1.8mm tread pitch.
There is a picture of it in the Audi Manual do you have an email address that I can send it to.
The forum does not allow to attach a picture.
Thanks again
Kai
TRB on Thu September 13, 2007 1:33 PM User is offlineView users profile
You can post images here. Depends on the type of browser you are using as to what icons you see when posting. Not to argue but I had a vendor snap on a R134a coupler this morning on a compressor he had in stock. So it would be nice to see what you have if you can get me an image.
PS: Click on my name and you're email program should open.
mk378 on Thu September 13, 2007 4:15 PM User is offline
Could be the aftermarket compressors come with standard fittings, the original one has a proprietary fitting that needs an adapter.
Kai on Fri September 14, 2007 10:56 AM User is offline
Tim, I sent the picture to this address [email protected] did you receive it?
Kai
TRB on Fri September 14, 2007 11:06 AM User is offlineView users profile
Yes and I could not locate any adapter like the one listed with any of my sources. Hate to say it but it my be a dealer item if they even carry it these days. Like I posted before my sources service port using a standard ACME fitting link this one.
iceman2555 on Fri September 14, 2007 11:43 AM User is offlineView users profile
TRB..post the photo....lets see what gives....noticed that some of the access ports are for the use of service at the manfactures level only...just a thought...but heck..just plain nosy......let me see.....let me see.....
TRB on Fri September 14, 2007 1:45 PM User is offlineView users profile
Sorry pal I deleted that email yesterday.
steve325is on Fri September 14, 2007 2:58 PM User is offline
How's this?
Audi also says you can remove the low pressure switch and tap in there.
-- Steve
Kai on Fri September 14, 2007 5:09 PM User is offline
Steve, thanks for posting the image I could not copy and paste the image from the Bentley manual software I ended up taking a picture of the screen and sending it.
Kai
Kai on Fri September 14, 2007 5:19 PM User is offline
Is it possible to remove the low pressure switch and install a T-fitting reinstall the
low pressure switch and add a permanent 134a low side valve for gauge connection?
Kai
Chick on Fri September 14, 2007 5:21 PM User is offlineView users profile
Chcik out Mastercools fittings for one that might work..Hope this helps..
Kai on Sat September 15, 2007 9:14 AM User is offline
Chick, thanks for sending that link but I don't see anything that will work apparently the treads on the valve are 8.9mm diameter and 1.8mm pitch.
Kai
