Engine keep shutting down when throttling
kareemevo on Sun September 09, 2007 1:58 PM User is offline
Year: 200
Make: mitsubishi
Model: pajero
Engine Size: 3.0
Refrigerant Type: r 134
Country of Origin: Japan
Ac works fine with cooling and all that ,the problem that i have is when ever i stop for a minutes the ac strip out the engine whenever the compressor comes on, it does not happen all the times but a bit worried sometiems you can hear like the the engine struggle to keep up. when the ac runs at throttle it run at about 1000rpm at idle about 600rpm any advice would appreciated.
Chick on Sun September 09, 2007 6:50 PM User is offlineView users profile
Time for a tune up, and code check to see if a sensor isn't workjing right..Any codes founds will point to the problem..Pressures would be helpful if everything else is normal..
kareemevo on Sun September 09, 2007 8:51 PM User is offline
thanks will do that and you know ok.
kareemevo on Sun September 09, 2007 8:53 PM User is offline
which sensor would reponsible for that behaviour?
Chick on Sun September 09, 2007 9:01 PM User is offlineView users profile
Idle control solinoid or sensor...Hope this helps..
kareemevo on Mon September 10, 2007 10:15 PM User is offline
awaiting diagnostic check so will let u guys know ok?
