02 z28 ac freezing up on the interstate.
john,??? on Thu September 06, 2007 3:42 PM User is offlineView users profile
Year: 02
Make: chevy
Model: camarp
Engine Size: 5.7
Refrigerant Type: 134
Ambient Temp: mid 70s
Pressure Low: na
Pressure High: na
this seems like the best place to ask, I asked my buddy that works at a shop that does a little bit of everything includeding a/c work and he don't know.
this one is my daily driver so I want it done right.... I took a long road trip in it a few months back and the condensor would freze up. the only setting it wouldn't happen on was bylevel, outside air and blower on max(which sucked for hours on end lol). anything less it would freeze in no time at all. and this was on hot days. at night I couldn't find anyway to keep it from freezing up.
the car has about 50k miles on it, the ac has never been touched. I haven't put gauges on it. since it doesn't do it around town at all, day or night. I'm planing on a trip in a few months and don't want to deal with turning the a/c on and all all the time again.
the temps around town are normal/outside air is just under 40*. max its low 30s. and these are hot florida days in rush hour traffic.
any ideas what I should check or replace or even a place to start? like I said, this ac is used whenever I'm in the car, pretty much day and night(no power windows).
Chick on Thu September 06, 2007 4:02 PM User is offlineView users profile
give us the pressures at idle and 1500 rpm..Thats always where you start.. Hope this helps..
john,??? on Thu September 06, 2007 6:03 PM User is offlineView users profile
idle and 1500... ok, I'll do that soon and post up. does it matter if its at night when its cooler or should I wait to do the test durning a hot day?
Edited: Thu September 06, 2007 at 6:05 PM by john,???
Chick on Thu September 06, 2007 6:45 PM User is offlineView users profile
So long as it's over 70 degrees will give us data we can use, but post the outside temp along with the pressures..Hope this helps..
High/low pressures, ambient temp, windows down, fan on high
Then get the pressures at idle and 1500rpm with the windows up, fan on low, AC on max..
GM Tech on Thu September 06, 2007 9:34 PM User is offline
control valve is set too low.............can be replaced,.........
Chick on Thu September 06, 2007 9:58 PM User is offlineView users profile
GM Tech is the "Master" with these, so I would have the system recovered (must be empty to change the control valve, and the AcDelco number for that one is 15-5452 and here's a pic of it
Goes in the rear head about the 6 o'clock position on your V7 compressor Hope this helps..
Chick on Thu September 06, 2007 10:08 PM User is offlineView users profile
Just to add, it's the same control valve from 94 and up V5's and V7's.... Should be easy to find..
john,??? on Thu September 06, 2007 10:39 PM User is offlineView users profile
sweet....
I will pick a new one up and stop by my buddy's shop and swap it out. I'll also get before and after pressures just incase.
is there a site sponsor I can order it from, be nice to give back in some way.
Chick on Fri September 07, 2007 5:49 AM User is offlineView users profile
0e-mail the guys at Ackits.com who sponsor this board. If they don't stock it, they can get it.. Great service on ALL you ac needs...
