Year: 1991
Make: chevrolet
Model: suburban
Engine Size: 5.7
Refrigerant Type: r134
Just wondering about the available vacuum pumps...
would the "economy" pump be adequate for pulling the vacuum on my suburban?
is the difference in the more expensive models going to be duty cycle?
if i can get my a/c working, i will only be using this pump on an ocassional basis.
also does the smaller pump pull an adequate vacuum, but it just takes longer to achieve?
thanks.
Dual unit system like the suburban I would go with the 5 CFM model.
Economy 5 Cfm Vacuum Pump
