evap prone to leak?
wrench on Sat September 01, 2007 10:30 AM User is offline
Year: 2004
Make: chrysler
Model: pacifica
Engine Size: 3.5L
Refrigerant Type: 134A
Ambient Temp: 90
Pressure Low: NA
Pressure High: NA
1= Any one know if those pacifica are prone to leak from the evaporator?
2= is there a rubber elbow at the evap drain?
thanks wrench
diesel is music, music is noise!
TRB on Sat September 01, 2007 11:41 AM User is offlineView users profile
It's a Chrysler, have not heard of to many issues so far. But if history repeats its self the core will leak. Diagram of the case assembly does not show a rubber hose as a drain tube. So I would imagine the case it self has a drain tube designed into it when bolted to the firewall.
avx on Sat September 01, 2007 10:31 PM User is offline
Pacifica is a remake of 4th-gen. minivan, but I understand only 3d gen. was known for a problem with
evaporators. Like TRB says, the HVAC housing has a stub pipe protruding through the firewall. The elbow
fits on it from within the engine compartment.
Edited: Sat September 01, 2007 at 10:33 PM by avx
