a/c works only for 5 seconds then dies
ptmar on Thu August 30, 2007 9:16 PM User is offline
Year: 1994
Make: toyota
Model: tercel
Engine Size: 3ee
Refrigerant Type: r134a
hi i installed a a/c in my car.everything is bnew except the ac amplifier and i modify the cooling unit wiring harness because what i got is with power steering, the only thing i need is freon and oil. went to a shop and have it done. now when i turn on the a/c it runs for 5 secs only then shut off . you can feel the air getting cooler and hear the magnetic clutch engages. when you turn it again it will do the same thing again and again. something is shutting it off. i presume oil and freon is in good pressure, all parts are brand new so it must be good. wiring i check and check from the repair manual and is correct. the only thing im thinking is the ac amplifier? but a brand new will cost me 150 . i just want to make sure its the a/c amplifier . i check the plug of the amplifier do some test and works fine. guys what do u thing
