access port problems w/Jeeps
Kaps on Sun August 26, 2007 1:24 AM User is offlineView users profile
Refrigerant Type: R134A
I have several coworkers driving Jeeps with R134A leaking access ports, hi & lo.
How do I tell whether I can remove the schrader valve only, or if I have to remove the port assembly?
Is this leaking unusual, or common?
Thanks for the help,
Kaps
A. C. Doyle said "Eliminate all other factors, and the one which remains must be the truth."
Chick on Sun August 26, 2007 6:14 AM User is offlineView users profile
If it has the "ball" type shrader, you can usually change the port, the other type (like a tire valve) you can change the shrader. Below os a pic of the Ball type. Always be carefull whick "Hex" you turn, as sometimes one is the actual line..
Regular "ball" type service port
Service port removed
The replacable Ball type service port
Be carefull not to twist this Hex, as you will ruin the line...Hope this helps..
Edited: Sun August 26, 2007 at 6:24 AM by Chick
