hi -lo pressure the same
ken w on Sat August 25, 2007 4:29 PM User is offline
Year: 1990
Make: chev
Model: cavalier
Engine Size: 2.2l
Refrigerant Type: r134a
what could be the possible cause of hi and low pressures being the same? orvice tube was cleaned but did no good. it was pretty dirty but not like the one that is shown in the black death message.
chris142 on Sat August 25, 2007 6:29 PM User is offline
Is the compressor running? If it is it's not pumping. It's broke.
Chick on Sat August 25, 2007 8:19 PM User is offlineView users profile
What are the pressures? Did you charge the system amount back into a deep vacuum?? Your car uses a variable displacement compressor, and the control valves do go bad, if your O tube was black, or even partially clogged, it's a good bet the compressor is shot. Most likely cause, poor retrofit in the past..Let us know the pressures and the answer to the vacuum/charge question and we can help you...
bohica2xo on Sat August 25, 2007 8:22 PM User is offline
You have a V5 compressor. Several different things could be going on.
Check to see that the center hub of the clutch is actually pulling in, and turning the compressor shaft.
If the compressor is turning, record the high & low side pressures - and post them.
B.
