Which oil?
mhfd112 on Thu August 09, 2007 7:37 AM User is offline
Year: 2003
Make: Chevy
Model: 1500hd
Engine Size: 6.0
What viscosity oil should I use in this truck? I was planning on using dec pag 150. I was doing a little reading on this truck while the parts are on they way. Read something about 525 viscosity oil for lubricating o-rings. Is that the kind of oil that is in the system too?
daman on Thu August 09, 2007 11:50 AM User is offlineView users profile
No the 525 is only to lube o rings and such,the PAG 150 goes in the system.
iceman2555 on Thu August 09, 2007 6:46 PM User is offlineView users profile
The 2003 truck may have the Denso 10S17P compressor. If this is correct the correct lubricant spec'd by GM is PAG 46. Be very careful if servicing this vehicle, some of this compressor have a pressure switch located in the rear head. If it becomes damaged, the entire compressor must be replaced....GM does not service the switch.
Good luck!!!!
daman on Thu August 09, 2007 7:34 PM User is offlineView users profile
Hmmm, i'll have to ask my father in law just had his '03 serviced and they used 150 in it....
mhfd112 on Thu August 09, 2007 9:23 PM User is offline
I think it is a 10S20F.
TRB on Fri August 10, 2007 11:51 AM User is offlineView users profile
10S20F is the bigger model for that vehicle. Both will work according to my data.
mhfd112 on Fri August 10, 2007 12:30 PM User is offline
What is the correct oil?
TRB on Fri August 10, 2007 3:35 PM User is offlineView users profile
DEC PAG 46
daman on Fri August 10, 2007 4:49 PM User is offlineView users profile
Originally posted by: TRB
DEC PAG 46
Tim you think 150 will hurt the pump?
my father in law says his work order says they used PAG 150 in his '03.
TRB on Fri August 10, 2007 4:57 PM User is offlineView users profile
I would not put too much worry in it if you have already added the PAG 150.
daman on Fri August 10, 2007 7:14 PM User is offlineView users profile
I didn't think so either, thanks.
mhfd112 on Fri November 23, 2007 7:45 PM User is offline
TRB on Fri November 23, 2007 10:17 PM User is offlineView users profile
Did you have another question? Oil question has been answered and Nylog is always best for o-rings.
