Hot Item from Mastercool.
TRB on Tue July 18, 2006 12:11 PM User is offlineView users profile
Recovers and removes moisture, oil and debris from refrigerant*. New recovery system offers a state of the art ½ HP oil-less compressor with built-in high volume cooling fan for fast recovery. Color-coded gauge identifies when filter dryer replacement is needed. Complete A/C recovery systems includes Recovery Unit with built in Oil Separator and Filter Dryer, 30 lb DOT approved Storage tank and Cable, 72” Yellow and Blue Hoses, R134a Low Side Coupler and Oil Purge Bottle.
Mastercool 69100 Complete A/C Recovery System.
GM Tech on Tue July 18, 2006 12:29 PM User is offline
Now- just set that 30 lb tank on a "zeroed out scale"and hit the recovery button- and you will have the "weighed - out" charge that was in the system- do it every time- build your confidence in your equipment- and use the same scale to recharge to system spec- and you will soon learn that the amount of refrigerant in a system is absolutely crucial to your a/c diagnostics.................I do like the price- the big units I use are $3200 at least- with 50 lb tanks...............
Edited: Tue July 18, 2006 at 12:30 PM by GM Tech
JeremyB on Tue July 18, 2006 3:19 PM User is offline
Do you need any extra hoses, or does the 69100 + set of manifold gauges let you recharge/discharge a system?
TRB on Tue July 18, 2006 3:48 PM User is offlineView users profile
You would use the recover cylinder just as you would a standard 30 lbs cylinder. So with this unit and a set of gauges you could install, recover and install if you like. Of course you would need to pump down the system before charging.
iceman2555 on Wed July 19, 2006 2:46 PM User is offlineView users profile
Can I have a sample to 'test'?????
TRB on Wed July 19, 2006 2:49 PM User is offlineView users profile
Hell no I given you enough stuff already.
iceman2555 on Wed July 19, 2006 3:41 PM User is offlineView users profile
Can I get a discount then.....say....95 %........that would do and not cause any undue attention to the other exorbitant charges on the expensive account........heck...Ill even pay shipping.
TRB on Wed July 19, 2006 5:19 PM User is offlineView users profile
Come on you know you have room on that account to pay at least internet price.
blacktj01 on Thu July 20, 2006 7:53 PM User is offline
Do you need a RecoveryMate (69500) to go along with the 69100? or does the 69100 clean the refrigerant well enough to reuse?
TRB on Thu July 20, 2006 8:53 PM User is offlineView users profile
According to the information I have the 69100 is all you need. This is their new updated version of reclaiming equipment. So you may see the other models disappear in the future. But I'm stating this as an opinion and not specking for Mastercool.
JeremyB on Sun August 24, 2008 11:42 PM User is offline
So is the filter good enough to be able to reuse recovered refrigerant?
How much more filtering does a shop qualityz machine have?
JeremyB on Tue August 26, 2008 2:44 PM User is offline
Ba-bump.
TRB on Tue August 26, 2008 2:54 PM User is offlineView users profile
Yes, never compared the two. That would be a question to ask Mastercool.
