How much Nylog to use on o-rings
emobley on Sun September 19, 2004 12:42 PM User is offline
Hi,
Just want to make sure I'm using the right amount of Nylog on my o-rings. I put Nylog on the tip of my index finger and rub it on the o-ring between my thumb and index finger.
However, I've heard that one should "string" Nylog on. I guess I would have to see the technique, but it sounds like it would be easy to use too much.
Ed
Chick on Sun September 19, 2004 5:20 PM User is offlineView users profile
Either way is fine..On threads I dab a bit on and string it around the threads..If using your finger, be sure it is "clean" of drit and grime..Hope this helps..
Anonymous on Mon September 20, 2004 4:18 AM User is offline
Why anyone would use nylog is beyond me. I've been doing a/c for twenty years and never used it, I've never had a leak after thousands of cars so I fail to see the necessity. I just dip the o-ring in the oil and put it on the fitting and tighten it up. Once the o-ring is compressed inside the fitting, there's absolutely no way it could ever leak unless you misthreaded it or something. I laugh at people who use nylog. You know how tight the fitting has to be to compress the o-ring, to withstand the pressures of an a/c system? Once the o-ring is compressed, that's it, NOTHING is getting past it, nylog or no nylog.
Chick on Mon September 20, 2004 6:32 AM User is offlineView users profile
Nylog is NOT meant to be a sealer...It conditions the O ring and keeps it from drying out. Also helps when you have to take a system apart where the nuts on the accumulators and other parts are so tight from the bonding of dissimular metals that they have to be sawed off...Nylog prevents that from happening. But, opinions are like a**holes, everyone has one, and you are entitled to yours...So, laugh away..
emobley on Mon September 20, 2004 10:06 AM User is offline
I've noticed that in some fittings the o-rings really get squeezed and in some they come our looking like new. In the latter case, should or thicker O-ring be used? Or more than one o-ring be used?
Ed
TRB on Mon September 20, 2004 11:12 AM User is offlineView users profile
Maybe you should try a bottle you might just learn something new! Never had a leak in a system in 20 years that is amazing. Dipping an o-ring in oil is fine. But if there is a better method why not use it! Nylog is an excellent product, which I would recomend on all a/c connections!
TXAB on Mon September 20, 2004 11:47 AM User is offline
Nylog works great just as Chick said. It is possible to break connections open much easier when using Nylog on the threads. It's also a Godsend for Ford springlock connections!!!
"Don't get stuck on stupid!"
---- Lt. Gen. Russel Honore
scusack71 on Sun December 28, 2008 11:12 PM User is offline
sorry, replying to wrong thread
Edited: Sun December 28, 2008 at 11:40 PM by scusack71
Dave in Texas on Fri January 02, 2009 8:29 AM User is offlineView users profile
I do my own work, but I'm no expert. I used the stuff because people who are experts advised me to. If nothing else, it's a belt & suspenders thing....
At 2, I went home with a 10. At 10 I woke up with a 2 !!
